TwinTurbo.NET: Nissan 300ZX forum - A soft pedal can also be from leaking brake booster
300ZMang
on October 02, 2013 at 8:15 AM
Re: OTHER symptoms of failing BMC?
posted by yummy18268
on October 02, 2013 at 03:19 AM
hoses. My pedal used to get softer after pumping it a few times. Replaced my BB hoses with silicon hoses and now it holds the pressure, no matter how many times they are pumped.
12:26:14 10/01/13
Could be a warped rotor
-Grimm-
13:25:29 10/01/13
not the rotors, light braking is normal
18:22:09 10/01/13
does it only pull to a certain side, or either side?
300ZMang
19:22:52 10/01/13
one side and only momentary unless you increase braking
23:10:55 10/02/13
Have you inspected the calipers further?
ttsmokin
00:34:10 10/03/13
I'll check out the calipers when I flush/bleed system
02:46:43 10/03/13
yummy18268
03:19:06 10/02/13
A soft pedal can also be from leaking brake booster -
300ZMang
08:15:49 10/02/13
Re: A soft pedal can also be from leaking brake booster
yummy18268
19:57:54 10/02/13
maybe i described it wrong but it feels nothing like w
300ZMang
20:01:24 10/02/13
Pedal doesn't go soft though
23:21:10 10/02/13
Wheel bearing (n/m)
300ZMang
07:59:18 10/03/13
